12" Ultra-MegaWoofer now available
0 Members and 1 Guest are viewing this topic. Read 6057 times.
John Casler
« on: 25 Dec 2007, 04:54 pm »
Most know that Brian has a 15", Ultra-MegaWoofer that is used in the VSS Subwoofer.
Well he has also decided to make the 12" Ultra-MegaWoofer which is currently only used in the VLA available too for those of you who have 12" woofer VMPS Models (RM-2 owners, and Original Sub owners)
They are priced at $225 each plus shipping.
Those who purchase the RM2 models can also add these as an option for $225 per pair over the standard megawoofers.  On the RM2jr, the price is $350 per pair to upgrade from the Polycone 12".
Mack
Re: 12" Ultra-MegaWoofer now available
« Reply #1 on: 25 Dec 2007, 05:54 pm »
Are these woofer upgrades available for the VMPS Super Tower III?  :scratch:
Brian Cheney
    • http://www.vmpsaudio.com
« Reply #2 on: 25 Dec 2007, 07:58 pm »
With some undamping of the PR these woofers will substitute directly for the 12" in the ST3.
Mack
« Reply #3 on: 25 Dec 2007, 09:37 pm »
B. thanks for the quick response. Can I also substitute the 15" active for the ultra-mega woofer version? Are the changes plug and play or do I have to do any mods to the enclosure? In the end what advantages am I going to have - Higher power handling? Deeper bass?
Woodsea
« Reply #4 on: 25 Dec 2007, 10:16 pm »
What will this do for the original?
Thanks and Merry Christmas!
John Casler
« Reply #5 on: 25 Dec 2007, 10:23 pm »
Deeper, More accurate, more power, and greater power handling.
If I'm not mistaken (B can correct me if wrong) but I think this 12" has a larger excursion and there for affects the internal cabinet pressures to a greater degree and as such the PR needs to be "lightened" (reducing the damping) so that it can respond to larger excursions also.
Mack
« Reply #6 on: 25 Dec 2007, 10:37 pm »
John can you pm me with pricing (2x15 2x12).
Thanks in advance.
prsalsa
« Reply #7 on: 12 Jan 2008, 09:58 pm »
Are they considering doing a 6.5" ultra mega woofer.
thx
frewdc.
prsalsa
« Reply #8 on: 6 Feb 2008, 07:43 pm »
Can they be used in the tower II se and what can I spec as an inprovement. Is there a upgrade for the 5 1/4 mid as well.
thx.
Brian Cheney
« Reply #9 on: 6 Feb 2008, 09:33 pm »
The new 12" is designed for the VLA and is 4 Ohms.  Its tonal balance is quite different from the 8 Ohm wcf woofer in the T2SE and is not a good substitute for it.
Ryan45872
« Reply #10 on: 6 Feb 2008, 09:57 pm »
Brian,
Any info on new 6 1/2's?
And is the new 12" a paper/kevlar like the new 15"?
Ryan
Brian Cheney
« Reply #11 on: 6 Feb 2008, 10:49 pm »
The new 12" has the some type of cone as the new 15" with a very large motor, 112 oz.
We've had the 40oz 6.5" for over a year now.  Fs is 29Hz.  It's quite a woofer. Features include Xmax of 8mm, 1.5" 4 layer VC, and metal phase plug/shorting ring.
Ryan45872
« Reply #12 on: 6 Feb 2008, 11:11 pm »
Thanks! :thumb:
Ryan
prsalsa
« Reply #13 on: 3 Mar 2008, 02:02 pm »
How about just the mega woofer for the t2se.How about the 5" mid ny replcements.
thx
