VBT Alpha D Subwoofer ( Now Thoroughbass.com)
0 Members and 1 Guest are viewing this topic. Read 2843 times.
witchdoctor
« on: 21 Sep 2003, 07:35 pm »
This sub uses a patented technology called VARTL to produce tight, low,
musical bass from a driver only 6 inches in diameter. The small driver moves incredibly fast allowing for seemless integration with my main speakers. It is a passive sub and I use the companies 200 watt amp to drive it. Nearly everyone who has heard my system can't tell a sub is playing until I turn it off. It works great with both music and HT.
Check their new site for more info  http://www.musicalsubwoofers.com/index.html
Doc
rkapadia@ROOP
« Reply #1 on: 22 Sep 2003, 06:41 pm »
I've been experimenting with these miniscule subs for a while now.  It's pretty astounding, as there's no visible cone!  Really, these subs are ideal for urban living, and also they excel at music.  Not for the HT sub-fanatics; but these subwoofers do a wonderful job blending with stereo mains.  They're efficiency and moderate load also mean they're an easy drive.
Rup
