Sound differences between the X-mtm's and X-ls's.
0 Members and 1 Guest are viewing this topic. Read 2451 times.
gprro
« on: 20 Dec 2007, 11:28 am »
Hi Danny,
hope it's ok to ask over here, figured you would know better than anyone. What are the differences between the x-mtm's and x-ls's supposed to be, other than the obvious bass and higher sensitivity. I recently got a pair of both, and they sound really different. The ls's tweeter sounds a db or two, too low, and the mtm's have too much top end, and are kind of hashy. The Ls's image better and are cleaner/clearer,fuller lower midrange, although they stage kind of deep (almost like pro logic II is turned on)? I haven't had a chance to talk with anyone at AV123 yet. They've been really busy, so I thought I would wait a little. The ls's have about 30-40 hours on them, the mtm's have about half that.
I'm ready for  my x-overs and parts too, after new Chrastmas or New Years maybe?  :hyper:
poseidonsvoice
    • 2 channel/7 channel setup
Re: Sound differences between the X-mtm's and X-ls's.
« Reply #1 on: 20 Dec 2007, 01:17 pm »
I suggest you let them both break in a little more. A good 100-150 hours each. You may be in for more wonderful, positive changes.
Best,
Anand.
Bill O'Connell
  • Retired . Music Lover
« Reply #2 on: 20 Dec 2007, 03:46 pm »
You may also want to check into the Isotek CD Enhancer for breaking in those drivers as I'm sure this would help speed up the process. Highly recommended!
 I know I will be using this burn-in tool once my LS9's arrive. Patiently waiting but the anticipation has me salivating :drool:
Danny Richie
« Reply #3 on: 20 Dec 2007, 05:05 pm »
Letting them both burn in for a while is a good idea. I would do that before making any decisions about tweaking them.
There were a few QC issues with the original tweeter in that output levels could be off a little one way or another.
After they have burned in for a good 100 hours or more and the X-LS still seems a little down in the top end then you can decrease the resistor value in line with the tweeter and bring it up a little.
If the X-MTM still sounds a little hot then you can add a resistor in line with the tweeter (at the front of the network) to knock it down a little.
I'll walk you through it when the time comes if you want to make some adjustments.
gprro
« Reply #4 on: 22 Dec 2007, 02:19 am »
yeah, I'll let them burn for a while, they're just completely different sounding, both off in their own ways. I'll probably upgrade them a little after a while. I was also talking about my OB7 x-overs and xbl woofers and parts. :hyper:
