Primaluna Prologue Five black with extra tubes open to trades w/Telefunkens
0 Members and 1 Guest are viewing this topic. Read 2231 times.
meby
Will consider trades of high quality sub-woofer or partial trade towards turntables or tonearms.  Will consider other interesting offers!  I am throwing in Telefunken 12AX7s and 12AU7s for asking price.
Soft-start circuit Extends component and tube life by powering up the amp gently every time you turn it on.
Tube plate fuse Protects the amplifier output stage. Other amps may need a trip to the shop if a tube fails. Not this one. Just plug in a new tube and fuse, and go.
Adaptive AutoBias™ Exclusive to PrimaLuna, this circuit monitors and adjusts bias automatically. Each power tube is monitored to stay in a peak operating range.
 No need for matched tubes, no bias adjustments. It also allows you to experiment with different power tubes. Plug in virtually any power tube. Adaptive AutoBias will automatically adjust itself! In addition to KT88s, you can use 6550, KT90, EL-34, KT77, 6CA7, 6L6GC, KT66, 7581, or even 6V6GT tubes, and any of their equivalents..
Custom designed output transformers Encapsulated low hum, wide bandwidth for great bass and extended highs. Designed by Marcel Croese and one of the most prestigious transformer designers in the USA .
Premium parts . Fully vented chassis, chassis-mounted ceramic tube sockets, Nichicon and Solen capacitors. WBT style speaker terminals. Gold plated input jacks.
Hand made with the finest point to point wiring, with workmanship equal to or better than any product you can buy at any price , period.
Chassis made of finely finished heavy gauge steel, and five step automotive quality finish. Each coat hand rubbed and polished. Removeable tube cage included no charge.
Toroidal power transformer for low hum, and a front end that is dead quiet.
Conservative design runs tubes easy for long life.
Specifications
Output: 36 watts x 2
Freq. Response: 20Hz-85kHz +/- .5db
THD: Less than 1% at full power
S/N Ratio: 89 db
Input Sensitivity: 810mV
Input Impedance: 100k Ohms
Power Consumption: 225 watts
Dimensions: 11" x 7.5 " x 15.5" (WxHxD)
Weight: 37.5 lbs
Inputs: 1 pair RCA
Outputs: 4 & 8 Ohm speaker taps
Tube Compliment:
2 - 12AX7
2 - 12AU7
4 - KT88
Will Include matched quad of EL-34s at asking price.
Paypal add 3%
« Last Edit: 8 Jan 2008, 04:10 am by meby »
mjosef
How about a photo?
meby
meby
meby
I am throwing in Telefunken 12AX7s and 12AU7s for asking price. :thumb:
KCI-JohnP
Hi Meby,
Would you happen to need a DIN-RCA phono cable?
John
