0 Members and 1 Guest are viewing this topic. Read 4496 times.
Is having numerous picture frames on walls to a dedicated audio room any worse than having the same space exposed with drywall? I'm mostly done with treating my room with about 15 pieces of room treatments from Realtraps and GIK and like the way the improvements have helped the overall sound. I'm wanted to put something else on the walls. Would a handful of large type glassed frames set me back some sound wise?Thanks,Rob S.
Actually you're comparing glass to paint (a thin, but hard surface). Bare drywall versus paint in a room makes a huge difference.How about oil paintings or lithographs?
If the glass is not on a first reflection point, you probably wouldn't notice a difference between glass and sheetrock.
Brian,Just walk into a drywalled room before and after painting. Its undeniably different, much more reflective. Even bare drywall to drywall that's been primed is different. And the difference between primed and painted is an even bigger difference.
I'm not sure how that little thin layer covering another thin layer of paper bonded to what equates acoustically to rock is going to change anything.
