0 Members and 1 Guest are viewing this topic. Read 9241 times.
Hey, Glenn, looking forward to those photos. Do the new panels come supplied with a means of hanging on a wall? And or, would it be beneficial to stagger them out from the wall?
Not to put the pressure on you guys, but if you want to be in the first batch of 242 elites you better order soon. It looks like we could have a back order before the first ones go out!! aa Glenn
Quote from: Glenn K on 17 Dec 2007, 09:21 pmNot to put the pressure on you guys, but if you want to be in the first batch of 242 elites you better order soon. It looks like we could have a back order before the first ones go out!! aa GlennGlenn:Sounds like a very successful product launch, and well deserved! How long a back order do you anticipate? I'll still need to work with you and Bryan to figure out the total "plan" for the room etc. AND decide on fabric blah blah blah (too many decisions, too many contractors, too little time ).
So... if I build wood frames to wrap around the panels I already own will it cause problems with the effectiveness? Since I have 12 of them replacement isn't exactly an option. Mike
Thanks Glenn, I have (I think) 8 of the 2" and 4 of the 4". I may just leave them as is but I had to ask. My new listening room should be done in early January, so I'll actually get to use all of them. Most are stored away in the basement at present.
