0 Members and 1 Guest are viewing this topic. Read 13445 times.
well i Think I will go with the AKG 701. what amp should I look at. I dont want to spend to much. around 100-200$.
Quote from: RawB8figure on 14 Dec 2007, 04:47 amwell i Think I will go with the AKG 701. what amp should I look at. I dont want to spend to much. around 100-200$.Actually, a lot of people at head-fi have the 701, it is a fantastic headphone that is one of the best around IF you have a good amp and source. The 701 is not easy to drive.The DarkVoice amps are a good match for the 701 . You might want to try their new Figaro amp. I think it around 200.00I have the DV 337 which is their top amp at around 700.00. It is a dual mono, 2 transformer, 2 power cords 2 volume controls.As a headphone system it sounds as good as my watt/puppies/ Rowland combo, both sourced from Transporter.The Zero DAC/AMP is also getting raves at headfi and is only around 150.00 and is a SS amp.
ecramer - don't say nothing touches the Grados until you have heard the ATH M50s! I am an early Grado adopter (1993/$1200), so know their sound.
another thing why are there two different types of boxs for the 701 on ebayhttp://flecom.fragmachines.com/head-fi/K701/DPP_0003_filtered.jpgandhttp://www.ugotadeal.com/images/AKG/K701-BOX-NEW.jpgare one of these a fake?????
now that I have looked into headphones, there are so many to pick from.So far I like the sennheiser 555,595AKG 701Audio technica M50Beyerdynamic 880
