Setting up remote trigger
0 Members and 1 Guest are viewing this topic. Read 1434 times.
alpsy
« on: 12 Dec 2007, 12:39 am »
hi guys,
full of questions today :)
read the manual and still not 100% sure how to do it
want to get my SP2 to trigger on and off my 6BSST & 4BSST.
can somebody please explain to me in really simple language how to connect it up?
thanks,
julie
  • The Demo is Everything!
    • http://www.bryston.com
Re: Setting up remote trigger
« Reply #1 on: 12 Dec 2007, 01:19 am »
Hi Julie,
Simply use a pair of wires (22 gauge is fine) connected to the 12 volt out on the s SP2 -use the "C" and "on/OFF".
Connect those two wires to the two 12 volt  'inputs' on the first amplifier and then the 'outs' on that amplifier to the 'ins' on the second amplifier.
Set the amplifier switch on the back to Remote trigger - 'REM' or 'External' depending on the amp and you should be set.
james
alpsy
« Reply #2 on: 12 Dec 2007, 03:40 am »
Thanks James.
Worked a treat :)
Got sound ... all connections working ... just need to tune it now.
Sounds great right out of the box :)
Julie
« Last Edit: 12 Dec 2007, 11:39 pm by alpsy »
