Looking for Speltz and/or Straley cables
0 Members and 1 Guest are viewing this topic. Read 1364 times.
Christof
« on: 5 Dec 2007, 01:48 pm »
If you have any that you would like to part with, I would like to speak with you.  Please be in contact via PM.
I'm looking for
IC's (3pairs)
Speaker Cables (2pairs)
25' internal hookup wire
Chris
walkern
Re: Looking for Speltz and/or Straley cables
« Reply #1 on: 6 Dec 2007, 07:26 pm »
PM sent
Turnandcough
« Reply #2 on: 6 Dec 2007, 08:43 pm »
PM sent
Christof
« Reply #3 on: 6 Dec 2007, 09:40 pm »
Thanks guys.  I'm almost set now with cables.
Chris
Christof
« Reply #4 on: 6 Dec 2007, 10:50 pm »
I will be using Odyssey Groneberg Quattro for internal wiring for both high and low pass filters.  I've ordered a complete set of Gronebergs including IC, speaker cables & PC's from Klaus which should arrive with The Candela, Dual Mono's and Symphonic Line amps.  This system will be well matched and will provide a reference point.  I can then switch cables in and out to get a taste for how different materials and geometry effects my system.  I also spoke with Gregg at Reality Cables and he will be providing cables to demo  :thumb:.   Should be an interesting ride if I can just tame my room a bit.
