Personally I have no interest in SS amps. They're just way too easy to design, practically anyone in electronics can do it. That's why there are already dozens of available kits out there. It makes no sense for me to do a copycat product. I prefer to focus on difficult, innovative, and ground breaking designs where there are few peers. My business can only exist if I offer something of more value than the next guy.
So in that respect, I am sticking with tubes. They require more ingenuity and there is less competition. They can also sound better! It plays to my strengths.
For the power amp, I'm not sure if I've bumped into physical limitations, only practical ones. You can always throw more and bigger tubes at it. There are the GM70, 6C33, and transmitter tubes. What I did discover was that every high powered tube amp out there is using feedback. Hey, sometimes it makes sense. I could copy them, but that is pointless, especially given the super low cost of the imports. Some of the Chinese amps retail for less than my raw part cost! Of course, my design is superior, but you wouldn't know that by a cursory review of specifications. It would be stupid for me to play their game on their field.
The PA-20 (or PP-20) design I came up with was a compromise. I set myself into a corner with severe restrictions. All tube, no feedback, available parts, reasonable size and cost. So it was not a cost-no-object where I could make it the size of a refrigerator. I made it very practical. It is compact, uses low cost tubes and transformers. It is all about topology. Now to get the performance out of it, that is where I lose power. I sacrifice power for a low output impedance, low distortion, good behaviour and stability. That is, I choose maximal sonics. And in my particular case, the power suffers. I pull 225 watts out of the wall to generate roughly 20W or 25W of audio output.
That's just the way the cookie crumbles. As for real-world speakers. Well, low sensitivity and complex crossovers are a crutch for inferior design, just like feedback. Maybe those aren't the speakers you really want.
And so I choose my path - above and beyond ordinary hi-end offerings.
jh
