Scan Speak 23W
0 Members and 1 Guest are viewing this topic. Read 17440 times.
chrismercurio
Re: Scan Speak 23W
« Reply #20 on: 6 Dec 2007, 07:42 pm »
It must be very satisfying and fun to play with some of the worlds best tranducers.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Scan Speak 23W
« Reply #21 on: 7 Dec 2007, 04:45 am »
Yes it is quite enjoyable. I did some nearfield tests today with the 15" Aura and had the room buzzing and rattling  :icon_lol:.
Hult
Re: Scan Speak 23W
« Reply #22 on: 8 Dec 2007, 05:20 pm »
To use the 23W it in a three way, would you need to go active? Or could it work with two per side in parallel for what would still be moderately low sensitivity?
Thanks for your time,
C
I'm using the 23w in a 3 way system. The project isn't finished yet but in my tests i feeding them from a 400W amp. active due the 23w's very low sensitivity. The bass is tight, dry and very clean. The long throw and the 400W amp. make this system to go very low and compensate the drivers low sensitivity.
Imperial
  • Love keeps us in the air, when we ought to fall.
Re: Scan Speak 23W
« Reply #23 on: 8 Dec 2007, 09:28 pm »
Very nice there, you should post more about this speaker in the LAB/DIY forum Mr Hult! What is this 27 - 36 Liters chamber?
It looks very nice!  :P
Imperial
Hult
Re: Scan Speak 23W
« Reply #24 on: 9 Dec 2007, 01:03 am »
Imperial
Tanks Imperial
It's a 38 liters closed chamber for the bas and 12.5 liters closed for the midrange.
I's a eliptical chamber made of multiple mdf layers.
The project is far from finished. I'm working on a new 3'way active crossover.
I've uploded som picturs of the construction in the gallery http://www.audiocircle.com/index.php?action=gallery;area=browse;user=44634
JoshK
Re: Scan Speak 23W
« Reply #25 on: 9 Dec 2007, 01:20 am »
What tweeter did you use?
chrismercurio
Re: Scan Speak 23W
« Reply #26 on: 9 Dec 2007, 01:22 am »
It looks like Vifa XT, Peerless Exclusive and an SS 23W.
C
Imperial
Re: Scan Speak 23W
« Reply #27 on: 9 Dec 2007, 01:44 am »
Nice project indeed.
If going fully active, I know this is a bit excessive but.. you should take a look
at the BSS Audio FDS-366T OMNIDRIVE COMPACT plus heh, that has gotta be the
most complicated name for any active filter ever...  :duh:. But it has the
Whise filter teq built in. That is very good for the sub part...
It's about as bad ass as it gets this in 3-way active filters.
Imperial
« Last Edit: 9 Dec 2007, 02:40 pm by Imperial »
Hult
Re: Scan Speak 23W
« Reply #28 on: 9 Dec 2007, 02:44 pm »
Imperial
The omnidrive could be a good solution but a bit too expensive for me. My eyes is now fixed on the Ground Sound DCN23 digital filter http://groundsound.com/dcn23.html If anybody have some experience with this filter please let me know. It's a 24bit 96Khz sample 3 channel filter as you can config from a PC. Because the Latency in digital filters nature I must use it for all channels and not only for the sub part. This is OK but I must have new amps for the mid/top drivers.
Hult
chrismercurio
Re: Scan Speak 23W
« Reply #29 on: 10 Dec 2007, 05:03 am »
Rick,
I ran the numbers for sealed enclosure size for this driver and came up with:
23W   Volume (liters)   Cubic Feet   Cubic inches
q=.65   49.97   1.7646768   3049.36151
q=.707   36.11   1.275214714   2203.571025
q=.577   89.91   3.175146909   5486.653859
What do you think the optimum loading is? Or, what is your preference for loading as in the Linanite woofer array?
C
Rick Craig
  • Selah Audio
Re: Scan Speak 23W
« Reply #30 on: 11 Dec 2007, 01:14 am »
Rick,
C
Lower "Q" alignments tend to drive the woofer really hard so I prefer to stay around .7 to .8 for the Q.
