Help needed with tonearm set up
0 Members and 1 Guest are viewing this topic. Read 2373 times.
JoshK
« on: 17 Sep 2003, 02:19 pm »
I was wondering if any Rega owners out there, or anyone with a RB300 type arm can help me with the distance of the spindle to tonearm pivot?
I have a protractor that helps with the fine tuning but it isn't very helpful in guiding the macro placement of the tonearm relative to the platter.  I know there are a couple of rega owners out there.  Anyone willing to break out a tape measure and measure the distance between the spindle and the pivot?
TIA,
JoshK
« Reply #1 on: 17 Sep 2003, 02:43 pm »
NM, I think I found it....maybe.
FYI, a great resource I found.
The Vinyl Engine
Psychicanimal
« Reply #2 on: 17 Sep 2003, 03:00 pm »
Quote from: JoshK
The Vinyl Engine
Hmm, the moderator/webmaster's signature reads:
Direct drive or die.
I wonder if he really knows what he's talking about... :?
michael w
« Reply #3 on: 18 Sep 2003, 02:19 am »
JaS uses a Technics SP10.
I think that should answer your question.
 :lol:
JoshK
« Reply #4 on: 18 Sep 2003, 01:06 pm »
It is still slightly unclear, but I think I have deduced that this measurement should be 222mm.  Anyone with a Rega arm willing to confirm?
Psychicanimal
« Reply #5 on: 18 Sep 2003, 01:14 pm »
Quote from: michael w
 :lol:
Just being sarcastic--Im a DD person myself.
Quote from: JoshK
Have you tried contacting the people at Teres?
penance
« Reply #6 on: 18 Sep 2003, 01:24 pm »
yep, for rega arms the spindle to arm center is 222mm +-2mm
hth
JoshK
« Reply #7 on: 18 Sep 2003, 01:30 pm »
I am pretty close to done setting up the Teres but only had a little bit of time the past two nights to work on it.   I am trying to make my arm pod flexible for additional arms done the road.  I am also thinking of adding a second arm pod for two arms.   The second arm would be for a cheap arm/cart setup for those questionable records you get in dumpster dives.
Wayne1
« Reply #8 on: 18 Sep 2003, 03:46 pm »
Josh,
If you don't have it already, pick up the Hi-Fi News Analogue Test LP.
The protractor that comes with it is very useful in setting your overhang.
The bias setting tracks are great for dialing in your anti-skating.
I do know that Chris Brady of Teres uses this to set up his personal table.
