Tube Buffer
0 Members and 1 Guest are viewing this topic. Read 809 times.
Charles Calkins
Tube Buffer
« on: 30 Nov 2007, 06:44 pm »
Could someone explain to me(dumdum)what a tube buffer is and how it would be integrated into an audio system?
                                     Cheers
                                     Charlie
Steve Eddy
    • http://www.q-audio.com
Re: Tube Buffer
« Reply #1 on: 1 Dec 2007, 05:07 pm »
A buffer is basically a circuit which provides a high input impedance and a low output impedance, but generally has no signal gain, i.e. voltage out is equal to voltage in. A tube buffer is just this circuit implemented with tubes and is usually intended to be inserted between a CD player and preamp in order to impart some "tube sound" into the system.
Some examples are Musical Fidelity's X10 and Decware's ZBOX.
se
