My bass system consists of 2 x 4 pcs. 8" Peerless HDS woofers, driven directly (no x-over) by an ICEpower amp.
I've tried wiring the woofers both in parallel and series. For my specific system, there was no difference in sound.
The bass system covers the range 20-250 Hz and uses non-vented boxes. The HDS drivers have shorting rings in the magnet system.
As so often before, things that in theory are supposed to make a difference, may not do so in practice. I do suspect, though, that the shorting rings in the HDS magnet system may play a not unimportant part in this case
P.S. Be careful when experimenting with parallel wiring. Some amps don't take too kindly to the low impedances (in my case down to 2 ohms!). Fortunately, my ICEpower amp seems to be quite sturdy, although I've later been told by B&O that they will not guarantee the stability of their amps at such low impedances.
I know use a combination of parallel and serial wiring, which gives me an 8 ohm impedance
