Dayton Woofer Tester 3
0 Members and 1 Guest are viewing this topic. Read 1915 times.
richidoo
« on: 29 Nov 2007, 12:28 am »
Anyone have experience with WT3?   Is it as accurate as S&L WT2? Does S&L make the WT3 for Dayton?
I need a driver tester for my own projects. I am deciding between WT2 and WT3. 3 seems to have easier software, tests faster, etc, but the ads may not tell the whole story.
Related question, What can "WT Pro" do that the other's can't that makes it worth $1000?
Rich
mgalusha
Re: Dayton Woofer Tester 3
« Reply #1 on: 29 Nov 2007, 01:17 am »
I have the WT2 and for my purposes it's just fine. Mine says Dayton but I'm pretty sure it was made by S&L. For my use I can't see an upgrade to the WT3
