0 Members and 1 Guest are viewing this topic. Read 45020 times.
While I'm still learning this stuff step by step, I'm still not completely comfortable evaluating possible candidates for a driver tube, so what about the 6SL7, or 6SN7 (or better yet their 12 volt filament versions, which are much cheaper), or the one mentioned earlier that Don Garber uses in his Fi amps?
I suppose a 12B4A will be overkill here too? ECC99?-- Jim
Aerius, JoshK, I'm not completely sure what you are basing much of your recommendations on for the various tubes and driver topologies. Are you using known formulas for calculating required slew rates, current drives, etc? Again, the scope of the project is to have a very simple 45 based SET amplifier and do this at a low cost. I did start with a textbook gain stage and a reasonable output stage with hum balance for the filament. But it's just a starting point, but there is some math behind it. I don't expect this to be a final circuit of course but will post updates as the design progresses.
Quote from: floobydust on 1 Dec 2007, 05:51 am Aerius, JoshK, I'm not completely sure what you are basing much of your recommendations on for the various tubes and driver topologies. Are you using known formulas for calculating required slew rates, current drives, etc? Again, the scope of the project is to have a very simple 45 based SET amplifier and do this at a low cost. I did start with a textbook gain stage and a reasonable output stage with hum balance for the filament. But it's just a starting point, but there is some math behind it. I don't expect this to be a final circuit of course but will post updates as the design progresses.The problem is the textbook ideals do not happen in the real world. Textbook theory assumes that the grid of the DHT is essentially a load with infinitely high impedance, and that it never draws grid current until it crosses over 0V. Unfortunately, neither is true in the real world, power triodes such as 45's, 2A3's, 300B, and so forth will start drawing grid current well before the grid gets anywhere close to 0V with respect to the cathode. The grid impedance can also be shockingly low, especially when it starts nearing the 0V.To make a long story short, it means a lot more current is needed than the textbook formulas would suggest, and that RC coupling is not a good idea if you want to push the amp anywhere near full output.
