Emu USB 0404 help?
0 Members and 1 Guest are viewing this topic. Read 1211 times.
Cacophonix
Emu USB 0404 help?
« on: 27 Nov 2007, 01:31 am »
Hi,
Has anyone tried to use the EMU alongside an external DAC?
I have been using this external soundcard to feed the candela preamp and khartago mono amps. But when i try to connect the optical outputs of this soundcard to the input of paradisea DAC, i don't hear any sound.
The manual seems to suggest that i can use optical outputs only if i feed optical data into this soundcard. Is this really the case?
Cacophonix
Re: Emu USB 0404 help?
« Reply #1 on: 27 Nov 2007, 03:06 pm »
Found the answer -
http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=642,E=0000000000291359153,K=479,Sxi=12,Case=obj(2114),VARSET=centric:1004,Kb=creative_emu
Basically you have to do a patch loop from the analog output to the analog input.
