My Ceiling Treatment Project
0 Members and 1 Guest are viewing this topic. Read 1880 times.
stereocilia
« on: 26 Nov 2007, 10:22 pm »
After reading about the benefits to treating first reflections I finally put 2 left-over 2 x 24 x 48 Sonex panels on my low ceiling at the reflection points.  (I say left-over because a friend of mine ordered 8 panels a few years ago and only needed 4).
I mounted them to the ceiling crappily, I must admit.  Here’s what I did and why.  I glued some .25” x 4” basswood strips to the back of the foam for support.  Then, I put a small plastic expansion anchor (#4, I think) in the center.  Yes, that’s right, a 2’x4’ foam panel supported by a single screw in the ceiling.  It works for now.  I just wasn’t willing to drill any more than that in case the sound didn’t improve much.   This also lets me rotate the foam so that I can experiment with the position a little.
Fortunately, the improvement is huge:  better imaging, less sibilance, and more detail.  But, the charcoal foam on the ceiling is ugly.  So, if (non-audiophile) guests come over I can take it down leaving only a single 3/16 hole per side which is hard to see in the textured ceiling.
Ideally, I would like to get both a better-looking white panel and way to remove it without leaving a bunch of holes or dangling eyelets all over the place.  After all, any blemish in a low ceiling hurts resale value more than in a high one.  I’m not sure if such a thing is even possible.
snoren78
Re: My Ceiling Treatment Project
« Reply #1 on: 29 Nov 2007, 07:52 pm »
I'd say go for more holes.  If you're worried about holes in the ceiling due to resale, all you have to do is take some white spackle to fill the hole and you'll never even know it's there without looking at it up close, which nobody does to a ceiling anyway.  No worries.
stereocilia
« Reply #2 on: 30 Nov 2007, 12:36 am »
Yeah, after more thought, I think you're right.  I'm still not ready to slap a bunch of glue on the ceiling, but I've gotten over the fear of poking some fasteners into the drywall.
(My college roomate once installed a ceiling fan into our dorm room.   :roll:  He spanned the ceiling by wedging 2x4s between the molding around the top of the walls and put an electrical box in the center.  Very high 'WTF' factor.  The wall got dinged but a little spackle saved our deposit on that one.)
Welcome to AC, BTW.
satfrat
« Reply #3 on: 30 Nov 2007, 01:28 am »
Got any pictures? I agree with everything you've said btw, I used a diffuser on my ceiling at the first refelection point and received simular results. I actually found a bigger perceived soundstage than I had with the side wall reflection points. I do have low 7' ceilings but i'm surprised more audiophiles don't treat their ceilings.
Oh yeah,,, I'm not married, that might make a small difference.  :lol:
Robin
stereocilia
« Reply #4 on: 30 Nov 2007, 01:49 am »
No pics yet.  If I take any the caption will be 'work in progress' or something.
I think what really may have triggered my ceiling treatment quest was noticing that the carpeted floor is about 3'10" away from he ribbon tweeter whereas the uncarpeted ceiling is only about 3'8" away.  Ain't nothin' like tall speakers in a short room to screw up the feng shui.
I also posted something a while ago about how I didn't regret moving the speakers so they are not surrounding the fireplace.  Well, guess where the speakers are now.   :oops:
