ht hookup
0 Members and 1 Guest are viewing this topic. Read 2318 times.
monte
ht hookup
« on: 25 Nov 2007, 08:06 pm »
Could someone tell me how to hookup the ht rca to my yamaha rxv1?
modwright
    • ModWright Instruments
Re: ht hookup
« Reply #1 on: 25 Nov 2007, 08:11 pm »
You simply run the front-left and front-right of the multi-channel analog outs from the receiver (Yamaha) to the HT/BP inputs.  When you want to run your system in multi-channel mode for Home theater or multi-channel audio, you simply turn the input select to the HT/BP input (input four) and toggle the HT/BP switch up if you want to bypass the preamps gain/volume control.
In this mode, the preamp is connected to the front channel amplifier, but is seen as a straight-wire - i.e. not in circuit.
I hope that this makes sense.
Dan
ted_b
Re: ht hookup
« Reply #2 on: 25 Nov 2007, 10:20 pm »
Dan,
Stupid question from a veteran Modwright'er:  why do you say "switch input to input 4" and then tell him to toggle up the HT/Bypass?  Doesn't the toggle do it, regardless of input selector?
Ted
modwright
Re: ht hookup
« Reply #3 on: 28 Nov 2007, 06:11 pm »
Hi Ted, no, the only input that goes to HT/BP is the HT/BP input.  This is actually a safety thing, otherwise it would be too easy to have someone unwittingly flip the HT/BP switch and get full volume.
Dan
ted_b
Re: ht hookup
« Reply #4 on: 28 Nov 2007, 07:48 pm »
Dan,
I meant it another way.  I realize that a variable-volumed processor or receiver needs to go the HT/Bypass input, not a fixed volume thing like a cd player (that would be a huge problem waiting to happen).  I meant:  once you have the correct source in the correct input, and want to use the HT bypass funtion, why does the user need to switch the toggle AND switch the input selector to input 4 ?  I have always just simply switched the HT/bypass toggle up and voila, my processors front l/r outputs are routed through the LS 36.5 unfettered, regardless of what the input selector knob is currently set to.
Ted
modwright
Re: ht hookup
« Reply #5 on: 29 Nov 2007, 05:20 pm »
The HT/BP in the 36.5 operates differently than the 9.0SE.  The HT/BP function also works with the unit powered off, which is different than the 9.0SE.
Dan
monte
Re: ht hookup
« Reply #6 on: 30 Nov 2007, 01:13 am »
Thanks for the reply Dan.Could you also tell me how to hookup my SONY 999es to the Yamaha.Thanks again.
modwright
Re: ht hookup
« Reply #7 on: 3 Dec 2007, 05:49 pm »
Please see my reply to what I believe is your post on the audiogon forum?
Dan
