0 Members and 1 Guest are viewing this topic. Read 4156 times.
Thanks for the math clue byteme, looks like 41-50" is a good size for me. I'll have plenty to learn to make a decision. I did watch Thanksgiving football on my bro-in-laws 62" (don't know brand or type) and the picture wasn't as good as my trinitron - everything was stretched out widthways and the detail wasn't superior. Have browsed some Samsung 50" and if I find one on sale or used I'll be ok (after xmas should be a good time to shop). Don
Quote from: nodiak on 24 Nov 2007, 11:30 pmThanks for the math clue byteme, looks like 41-50" is a good size for me. I'll have plenty to learn to make a decision. I did watch Thanksgiving football on my bro-in-laws 62" (don't know brand or type) and the picture wasn't as good as my trinitron - everything was stretched out widthways and the detail wasn't superior. Have browsed some Samsung 50" and if I find one on sale or used I'll be ok (after xmas should be a good time to shop). DonThat could be the content, and not the TV. A TV of that size needs a good HD signal!
My BIL has a 50+" Sony TV. He has it hooked up with the worst possible signal and components, and brags about the picture. I have been biting my lip and nodding (I am not going to stick my nose into his business, and I don't want to get sucked into a project 45 miles from home). If he only knew what he is missing.
For those that aren't used to it SD is VERY hard to watch on an HD TV. No matter what upconverting algo they use the fact of the matter is 480i has a limited amount of pixels. Your 32" TV is made for that number and does a real good job of displaying SD I'm sure. When you blow up 480i into 50" on an HD that isn't made for SD it's GOING TO LOOK WORSE. There is no way around that.However, once you see HD you're not gonna watch SD unless there is no other option. Period.I don't know what you've got for a source but typically, OTA (over the air) is going to be the best picture you'll get, then DBS (Dish or DirectTV) and then cable. Cable sux IMO - they compress more than the other sources, the don't provide many of their channels in digital (which again could contribute to your picture quality in SD) and they don't offer as many HD channels as DBS. I've had Dish for almost 8 years and would never go back.
Btye - Do you remember when you helped me help a friend a few years ago? He is so happy with his set up - and it was all done on the cheap. Got a used Pioneer receiver here on AC, the great deal on the Polks and cables, and then a great deal on a Panny projector. I think his total cost was under $4K. He is still grinning ear to ear!
I think most channels I watch are perfectly fine in standard definition reconfigured to high definition. Granted, I watch some talking heads, and a few home improvement shows. I don't really need to see these in high definition. What becomes very hard to watch is sports. Sports is much better in HD, although I find the cable version of the channels to be quite compressed with many artifacts. In fact, sometimes the digital artifacts are so bad that it's hard to watch. A good HD signal is very good for outdoor channels and sports. I also like Dish, but I've had cable for a while now. I still think I like Dish a bit better. I think Dish offers more options for channels, but I've also heard they no longer let you buy the equipment. That can get expensive, as the rental fees are in the $10 range per month, then they charge you extra for an additional receiver, and they used to charge a per-month fee for the DVR data (which is ridiculous, considering all the data is there) or "use" of the PVR. So, you start at $43/month for programming, and your bill will be $80/month. Dish's website is useless for determining how much you'll actually be paying. If I ever cut down enough trees, I might consider going back to Dish, but I'll have to call them, ask them the true price of having one DVR and one HD receiver, and compare to cable.
A dissenting voice in the cable vs DTV video quality issue:I found the opposite of the above expressed views, having had both DISH and DTV for about 4years prior to switching to cable almost 2 years ago. Cable (Cablevision in my area) I found had much better video quality than either of the aforementioned Satellite companies. Many of the cable channels were a pain to watch (Scifi, tnt, usa, etc) with blotching in dark scenes(from over compression) and occasional break-up during any kind of overcast weather. Switching to cable during their 3 for 1 promotion, I saw deeper/richer colors...and none of the weather induced loss of signal issues. As to price...now that the year promotion package price is over my tv bill is higher by about 15-20%(vs DTV)...but no way am I going back to DSL, and I am leery of DTV or DISH...they promise a lot but their delivery does not always match their aspirations.Sure its been about 2 years, maybe they have improved..I dunno. Over at AVS there are other viewers with similar viewing results as myself, so I know its not just me. I would love to try FOIS, but its not yet available in my area.Just my 2-cents.
