headphone amp question
0 Members and 1 Guest are viewing this topic. Read 1652 times.
ratso
« on: 19 Nov 2007, 12:15 am »
forgive a dumb question. if i wanted to mod my headphone amp to achieve more gain
(db) output, what piece is physically being replaced? is it the opamp?
BradJudy
Re: headphone amp question
« Reply #1 on: 19 Nov 2007, 01:52 am »
Replacing the op-amp will not (in general) change the gain.  It's likely you'd have to change the resistors used around the op-amp.
ratso
« Reply #2 on: 19 Nov 2007, 01:55 am »
thanx brad, thinking about having my amp modded and was wondering how
big a surgery this would be.. now to find someone to do it.
boead
« Reply #3 on: 19 Nov 2007, 04:00 am »
Gain can be related to the impedance of the headphones and how well they are matched to the amps design and components.
What headphone amp and headphones are you talking about?
ratso
« Reply #4 on: 19 Nov 2007, 04:06 am »
actually i am not using it as a headphone amp. i use my channel islands audio as a preamp to get some gain for my modded squeezebox which then goes directly into my power amps. sounds awesome but a touch more gain would be useful if possible. i have contacted CI to see what they say.
