I was much like Wayner - preferring tube preamp driving SS amps - the 3 dimensional nature was good. But 10 seconds in to hearing a
SS pre-amp driving mono tube amps and I was sold on that combo
instantly.
In my case I went from a
Dynaco PAS-4 (tube preamp) happily passing it to
Odyssey Khartago Extreme amps to something I've even happier about now. It has nothing to do with Odyssey offerings - which are superb SS amps (the best SS amps that I ever owned)
The lowest level signals, especially if you enjoy vinyl (typically, 1/20th to 1/400th or less voltage than CD outputs) beg for as
clean a step-up as possible. If you pass that to a capable tube amp(s) (that is, one that is capable of driving your speakers with adequate headroom for peak passages) you have ultra-quiet step-up that can only be achieved with solid state with the purity and 3 dimensionality that tubes bring to your music.
SS preamps seem to provide a 'backbone' of sorts to the music that I haven't been able to approximate with tube preamps.....even those that have been solid state regulated.
If you have tube amps that are either tube or solid state regulated (
not rectified), you achieve considerably more chest-thumping bass 'tightness' that is usually the domain of solid state amps.
If you add a powered subwoofer(s) to the mix - you're further relieving your tube amp of the heaviest bass duties and you can achieve some smile-inducing bass heft and 'tightness' back into the sonic realm
So, SS preamp and tube amps for me - an unlikely electrical match as tubes typically step-up voltages better and solid state better develops current (all the better to drive most complex speaker loads). The more you simplify your speaker loads, the more tolerant of tube amps your system will be - and you can enjoy the excellent pairing of a SS pre-amp and tube amp(s) more completely
If you're into vinyl especially, you
might want to turn your Odyssey / Candela up on it's conventional head and try it...
I've never been happier
My current system:
Bell Dual Mono Integrateds (10 watt
tube units powering 6.5" mid-woofers and tweeter)
Mitubishi DA-C20 working as
SS phono preamp and providing AM/FM
Gallo TR-1 (100 watt) subwoofer (dedicated below 80hz)
Linaeum Tower speakers (80hz and up)
CD is run straight into the Bell's....the added liquidity of
all tube seems to benefit CD playback.
