0 Members and 1 Guest are viewing this topic. Read 10098 times.
Some things you can do to enhance BYOB sound:Install a real heatsink, lower the operating temperature and elimate the distortion of thermal protection trying to kick in. The stock heatsink is just for show, it doesn't even touch the chip. With no heatsink the chip can make no power without coming into thermal protection, which sounds like you're describing. I made a post a while back with pics about a heatsink from Mouser that works great, about $10. The heatsink must touch the entire chip tab with heat grease. http://www.audiocircle.com/index.php?topic=47130.msg442242#msg442242
Also play it into a 4 ohm speaker, to get more current out of it (10W at clipping.) It is not happy playing into high impedance drivers like some single drivers or exotics. Output power falls to nothing and you can hear the clipping and see it easily on a scope. At 8ohms resistive load, it makes 5W at onset of clipping. I have 14.5 ohm speakers, 95dB sensitive, and it clips readily. Obviously you already have speakers. Maybe try a pad, although I thin kyou will hear it with 115dB sensitivity, wow!
Last thing to try is run the chip on a race car battery that gives 16V nominal, instead of 12. Or make an unregulated 16V/10A DC supply with some nice filter caps like Jensen 4 pole. The chip has good ripple rejection, so you might get by without a regulator. If you need a regulated supply, Paul Hynes can hook you up, but his stuff is ultimate high end, so be prepared to pay. Input power can never exceed 18V while it is turned on, which is why he says disconnect before charging (with normal fast chargers.) Playing at 16V the BYOBs specs are much better than 12V. More power, less distortion. It uses a car audio chip, which is designed to run on a car battery plus alternator at the same time, which is usually about 14.5V or more. Rich
a new battery cable (apparently a speaker cable evidence siren is good)
The problem is, I keep returning to my 2A3 amp. Yes, the 2A3 amp is not quite as detailed and a little softer/looser in the bass, but the organic nature of sound, the immediacy and physical tangibility of intruments, the naturalness and emotion simply can't be beat. I have rotated all these amps in/out of my system at least 50 times and while each has some virtues the others don't posses, I keep returning to the 2A3 because I literally relax into the music and forget about stereo-stuff while listening.
Now I can turn up the volume of BYOB amp to 12 o'clock after adding the 36K to the outputs. This would make the vocals more revealing and lively.
