Pacecar+DAC-1 or Modded DAC-1 USB
0 Members and 1 Guest are viewing this topic. Read 1698 times.
bigamp
« on: 16 Nov 2007, 11:00 pm »
I'm looking for a DAC for my office, so I don't want to spend many thousands.  Although this is several thousands:  Would I get a better result using 1) a PaceCar into an unmodded Benchmark DAC-1 using S-PDIF/coax or 2) USB into a Turbo Modded DAC-1 USB or 3) Off-Ramp I2S driving Benchmark DAC-1 with I2S and minimum mods?
Obviously I2S PaceCar into a fully Turbo Modded DAC-1 is best case, but more than I want to spend.
« Last Edit: 16 Nov 2007, 11:21 pm by bigamp »
audioengr
Re: Pacecar+DAC-1 or Modded DAC-1 USB
« Reply #1 on: 17 Nov 2007, 12:02 am »
#1 is a non-started IMO.
#2 is great, but only with the Superclock4, Turbomod and op-amp upgrade ($3250)  Without the Superclock4, it is just very good.  Without the op-amps it is a bit thin sounding.
The Off-Ramp I2S and DAC-1 with I2S and minimum mods would be: $1695.00.  I would add the op-amp upgrade for $300 and $200 for the Turbomod latest change to get you to $2195 total.  This one gives you the Superclock4 in the Off-Ramp, the flexibility of I2S so you can add Pace-Car later if you want to do SB3 etc. and it is not an upsampler, so you can get the benefit of upsampling on the PC or MAC.  This is my pick.
Steve N.
bigamp
« Reply #2 on: 17 Nov 2007, 12:09 am »
Steve, thanks!  Great!  That is very helpful.  Will order soon.  - Chris
