electronic crossovers
0 Members and 1 Guest are viewing this topic. Read 3340 times.
zipidachimp
« on: 16 Nov 2007, 07:23 pm »
I noticed from another thread a company called 'SHRED MUSIC'. browsing through their catalog, I noticed an electronic crossover, 'soundbarrier' stereo 2/3/4 way for $150.00
http://www.shredmuzic.com/product_p/201-994.htm  :o
has anyone experience with this, or similar?
Russell Dawkins
Re: electronic crossovers
« Reply #1 on: 16 Nov 2007, 07:27 pm »
gotta say "Shred" and "Soundbarrier" are not the most encouraging choices of names for devices I want handling my audio!!
zipidachimp
« Reply #2 on: 16 Nov 2007, 07:36 pm »
or 'zipidachimp' ? sometimes you either gotta have faith, or close your eyes and jump! :lol:
or, how about a dbx223?
oops! cancel this thread, I just spotted it on page 10 ! :oops:
« Last Edit: 17 Nov 2007, 08:57 pm by zipidachimp »
jeffreybehr
« Reply #3 on: 9 Dec 2007, 12:11 am »
Zip, I LOVE your signature.  Me too.
All 3 are OB including the bass.
zipidachimp
« Reply #4 on: 9 Dec 2007, 09:19 am »
mr. jbehr: your obs put mine to shame! sniff. standing in corner now. :oops:
p.s.: how do you wire all those drivers and still get 8 ohms?
jeffreybehr
« Reply #5 on: 10 Dec 2007, 03:49 am »
Oh, buck up, Zipi, you too can make 'em!
The eight 4-Ohm drivers are wired in series/parallel.  First wire 4 in series and the other 4 in series.  That gives you 16 plus 16 Ohms.  Put those 2 in parallel for 8 Ohms.  My finished version will use 9 drivers in s/p for 4 Ohms-- 3-each in series for 12 Ohms and those 3 in parallel for 4 Ohms.
zipidachimp
« Reply #6 on: 10 Dec 2007, 06:39 am »
see! told ya I was a noob! :lol:
mcgsxr
« Reply #7 on: 12 Dec 2007, 01:13 pm »
Mr Chimp, I am not sure if you are trying to Xover subs to mains or not, but if you are, I found this creature a fantastic investment.
http://www.reckhorn.com/index.php?ln=en&prod=f1
Available in Canada from our friends on the West coast - http://www.creativesound.ca/
All the best, and keep experimenting, that is how the learning is best done!
Russell Dawkins
« Reply #8 on: 12 Dec 2007, 01:46 pm »
This device does not seem to support stereo subs though - they speak of two mono sub outs, albeit with different high cut frequencies to each. Presumably, each sub out is a sum of the stereo in.
scorpion
« Reply #9 on: 12 Dec 2007, 05:28 pm »
As you can see from this schema, it is not that hard to modify the Reckhorn for stereo bass if your a bit handy with electronics.
/Erling
zipidachimp
« Reply #10 on: 12 Dec 2007, 07:09 pm »
my idea was to adjust the tweeter cross, to tailor the highs to my OB. on another thread, i mentioned replacing my fr with a dome, and how the sound did not improve. my stereo sub has internal adjustable XO from 200 down.
this first project was done on a whim. after new years, I'm gonna do one proper with an Alpha 10" and a good full range 4 or 5 incher, mimicing the project done by -Richard- but a tad smaller, and with decent woodwork. thanks for the help.
« Last Edit: 12 Dec 2007, 07:20 pm by zipidachimp »
