Piccolo switch orientation
0 Members and 1 Guest are viewing this topic. Read 1159 times.
John Swenson
« on: 16 Nov 2007, 07:34 am »
I'm putting a piccolo half kit together and noticed the two switches can be installed on the board in multiple orientations. The manual doesn't list any specific orientation, does it matter which orientation is used?
John S.
ecir38
Re: Piccolo switch orientation
« Reply #1 on: 16 Nov 2007, 01:36 pm »
Quote from manual "Install rotary switches with the alignment stub toward the bottom. Cut stub off."
John Swenson
« Reply #2 on: 16 Nov 2007, 01:55 pm »
I went over the manual 6 times and didn't see that.  :duh:
My wife says I'm forgetting things now, I guess I'm not seeing either!
John S.
