Question about the Clarinet balance control pot.....
0 Members and 1 Guest are viewing this topic. Read 1687 times.
tubesforever
I don't like pots as a rule, is the Clarinet 50k balance control pot always in the circuit, or does it have a detente position where it is bypassed?
If not, could I simply solder up a simple on off on switch work to perform bypass operation?
Thanks in advance for your input.
hagtech
    • http://www.hagtech.com
Re: Question about the Clarinet balance control pot.....
« Reply #1 on: 14 Nov 2007, 10:16 pm »
The detent position does not bypass.  You can jumper it out.  I believe the info in given in manual.
jh
