IPod Headphone vs. Docking Output
0 Members and 1 Guest are viewing this topic. Read 3724 times.
BrassEar
« on: 13 Nov 2007, 05:57 pm »
For a classic iPod driving a high end system, is it preferable to drive the preamp inputs from the docking station outputs vs. the headphone outs? I assume so since their must be an additional headphone opamp/buffer on the variable output that could degrade the sound.
Also, is the docking station audio fixed at 2V like most sources?
TIA
Vinnie R.
    • http://www.vinnierossi.com
Re: IPod Headphone vs. Docking Output
« Reply #1 on: 14 Nov 2007, 01:49 am »
TIA
Hi BrassEar,
Correct... for connecting to a preamp (or integrated amp), the best way to go is to tap the line-out signal (constant voltage... does not pass through the headphone stage or the volume control stage) from the dock connector.  I believe the line-out is around 1Vrms.
Ken at ALO Audio (www.aloaudio.com) makes some really excellent iPod dock to RCA plug cables.
Best regards,
Vinnie
tomjtx
« Reply #2 on: 14 Nov 2007, 03:15 am »
Check out head-direct.com
They have some excellent line out docks that are reasonably priced and sound great
