0 Members and 1 Guest are viewing this topic. Read 12416 times.
Man! This is BIG! Levi is getting his groove back!
As for the fear of buying a cartridge you may not like, I have a drawer full of them.
Grado's are good cartridges with the right turntable. They do have tracking issues that some table/arm combos expose. Perhaps there are better choices out there.
I will conquer when I figure out what the real problem is.
The PT9 is a medium mass arm with adjustable VTA, LC-OFC litz wiring, a fixed and damped headshell, removable DIN tonearm cable, and adjustable pivot damping which allows higher effective mass and compatibility even with cartridges lacking internal damping, such as Grados or Deccas.The adjustable pivot damping allows the arm to behave as though it has additional mass at higher frequencies without affecting the moving mass at low frequencies. If an arm has too much weight or resistance, it has a hard time tracking the record grove properly. The advantage of a heavier arm is that it prevents the movement of the stylus in the groove from affecting the movement of the tonearm. The included damping oil lets you decide how much damping the arm will exhibit, and thereby maximize the arm's performance for a given cartridge.
There goes my TT budget. Thanks for all the TT recommendations.
