0 Members and 1 Guest are viewing this topic. Read 3036 times.
There is a vendor that is claiming that which....
....... As I said, the filter injects a ringing character on to the circuit which helps smooth out odd harmonic frequencies above 60Hz. Instead of rolling off the frequencies as many filter designs do, we prefer to fill in the gaps of dip harmonics and reduce peak harmonics to offer a flatter frequency response. Series vs. parallel allows the design to offer power factor correction for the component placed after the filter on the circuit. Items prior to our filter experience a different effect because the leakage of the filter on the neutral increases the magnetic field within the geometry of the in-wall wiring. The increased magnetic field acts as a passive choke and rolls off the ringing charcater of the filter and anything else that may be circulating throughout the phase and interacting on the treated circuit.I hope this clears things up for you.
I'm not questioning the benefits of putting it before or after the load, but rather the nomenclature of calling it series vs parallel. If we "rename" terms like this then it just leads to confusion and potential miswiring with serious consequences.
