Ascendant Audio Atlas 15"
0 Members and 1 Guest are viewing this topic. Read 2002 times.
danssoslow
« on: 9 Nov 2007, 11:50 pm »
I'm looking to sel my AA Atlas 15" subwoofer. It's brand new, in the box. The shipping date on the box it was sent in is March 02, 2005. There it has sat in a closet, taken out a couple of times to oogle or take measurements. It has never been powered up.
This is a N.O.S., pre AA going in another direction subwoofer. This means I paid the original $175 shipped for the sub. :cry:
I'm looking to get my investment backout of it, but might be willing give a little. So it's $175 shipped CONUS for the moment.
My plans are to use the funds to purchase a ShivaX, so a trade for a used one in excellent shape would be square with me if anyone is interested.
Thanks for looking, and I have quite a few references on DIYMA and on ebay under the name danisugly. Any questions, please don't hesitate to ask!
Thanks again,
Dan
gprro
Re: Ascendant Audio Atlas 15"
« Reply #1 on: 10 Nov 2007, 01:19 am »
Good sub for the money. I have a couple. Did you take T/S measurements? PM me if you want.
danssoslow
« Reply #2 on: 10 Nov 2007, 02:26 am »
Thanks for the endorsment, gprro. :thumb:
I would like to add that I'm not big on making my first posts a sales; but at the moment I'm more or less lurking and learning.
Here are the T/S params for each 2'nd coil configuration:
Low Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .392
Qts .37
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 11.7
Spl 1W/1M 91.5 dB
Spl 2.83V/1M 95.5 dB
Le .86 mH
Cms .388 mm/N
No. .904
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
Mid Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .483
Qts .45
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 10.3
Spl 1W/1M 90.6 dB
Spl 2.83V/1M 94.5 dB
Le .86 mH
Cms .388 mm/N
No. .711
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
High Qts Specs
Fs 21.5 Hz
Qms 6.56
Qes .624
Qts .57
Vas 364 L
Re 2.8 ohms
Znom 4 ohms
Xmax 18 mm
Sd 810 cm2
Mms 139 g
Vd 2.91 L
RMS Power 300 watts
BL 8.5
Spl 1W/1M 89.5 dB
Spl 2.83V/1M 93.5 dB
Le .86 mH
Cms .388 mm/N
No. .567
Cutout 14.125"
Diameter 15.5"
Depth 7.25"
Weight 24 pounds
danssoslow
« Reply #3 on: 11 Nov 2007, 03:12 pm »
$150 OBO
danssoslow
« Reply #4 on: 13 Nov 2007, 02:30 am »
$130 dollars shipped.  :o
danssoslow
« Reply #5 on: 17 Nov 2007, 12:59 pm »
No longer for sale.
