AUDIO ELEGANCE IS REAL FURNITURE FOR AUDIOPHILES
0 Members and 1 Guest are viewing this topic. Read 3019 times.
osageaudioproducts
    • Osage Audio Products
« on: 9 Nov 2007, 12:38 am »
RESERVE YOUR AUDIO ELEGANCE AUDIO FURNITURE NOW.  PRICES START AS LOW AS $799.00!  A FEW DEMO PIECES ARE ALSO AVAILABLE ON A VERY LIMITED BASIS.  CALL 573-696-3551 OR EMAIL [email protected] FOR DETAILS.
Upgrade the quality and performance of what your turntable, amplifier, and the rest of your gear is sitting on to match the quality and performance of your gear!
Why put your audio gear on wobbly stands with plastic-laminated shelves, or on a stand that doesn’t match your furniture when you can get audiophile performance and fine, handcrafted furniture all in one package?
The Audio Elegance Audio Furniture Turntable Wall Shelf combines real furniture with audiophile performance and features not found in any other turntable wall shelf.
The Audio Elegance Turntable Wall Shelf will handle weights in excess of 160 pounds when properly mounted to the framing studs in your wall.
The turntable platform is isolated from the frame for resonance resistance and easy, precise leveling of your turntable.
The isolated turntable platform is mass-loadable with your choice of materials.
All Audio Elegance Turntable Wall Shelf selections are manufactured from solid, select-grade hardwoods and finished with high-end, furniture-grade lacquers.
Every Audio Elegance Audio Furniture product carries a full, 5 year warranty on materials and workmanship.
Your Audio Elegance Turntable Wall Shelf can be manufactured in nearly any size or of any hardwood that you desire!  Ask about our custom design and manufacture service.
HOW ABOUT A HIGH-PERFORMANCE, FURNITURE-GRADE PLACE TO PUT YOUR RECORDS AS WELL?
The new Audio Elegance Audio Furniture LP Storage System is the world’s best!
Using our “stacking tier” technology as a design basis, we have created LP storage that is unmatched in the industry for beauty, rigidity, stability, flexibility, and load-bearing capabilities.
The base unit of the Audio Elegance LP Storage System can be added to at any time to create additional storage, all the way up to 8 feet in height.  ADD MORE STORAGE SPACE WHEN YOU NEED IT!
The construction design and execution is extremely rigid and stable.  No sagging shelves or wobbly legs when loaded with your precious LP’s.
A 4 foot wide by 8 foot tall Audio Elegance LP Storage System will easily hold in excess of 1500 pounds without fear of damage to the LP Storage System or risk of collapse.
Audio Elegance LP Storage Systems are constructed, finished, and presented as real, fine furniture, perfectly at home in the most elegant of rooms.
Vertical shelf spacing can be specified to fit LP’s, CD’s, books, curios, or any combination or items.  Vertical spacing can also be changed at any time to accommodate your changing needs.
As with all Audio Elegance Audio Furniture selections, the LP Storage System is backed by a 5 year warranty on materials and workmanship.
ALL OF OUR PRODUCT OFFERINGS ARE SUPERIORLY RIGID AND STABLE.  ALL AUDIO ELEGANCE EQUIPMENT RACKS ARE DESIGNED FOR THE ULTIMATE IN CONFIGURATION FLEXIBILITY.  VERTICAL SPACING CAN BE CHANGED TO MEET YOUR NEEDS.  THIS MEANS NOT HAVING TO BUY A NEW EQUIPMENT RACK OR STORAGE SYSTEM AS YOUR NEEDS CHANGE.
All Audio Elegance Audio Furniture selections are proudly made in the USA by a master-level cabinetmaker.
Please visit our website at www.osageaudio.com or call 573-696-3551, or email [email protected] for more information and for pricing on sizes and materials to meet your specific needs.
Osage Audio Products, LLC is seeking retail dealers for the Audio Elegance Audio Furniture lines as well as our other fine products.  For information please contact Jim Pendleton at 573-696-3551 or [email protected].
Musicalmaniac
Re: AUDIO ELEGANCE IS REAL FURNITURE FOR AUDIOPHILES
« Reply #1 on: 29 Feb 2008, 04:00 pm »
Any analog lovers out there?
