0 Members and 1 Guest are viewing this topic. Read 7966 times.
Are you going to get the na-bmx temporarily and then do the module from Selectronic later?
Sean,Probably. I've ordered it and once the Selectronic stuff becomes available I'll likely order it. The kit from Jan Didden arrived yesterday, so I have much work to do. At this point my DCX is in quite a few pieces.
Quote from: PaulHilgeman on 14 Nov 2007, 02:41 amOr just buy EXACTLY this:http://www.fullcompass.com/product/264015.htmlMakertek has these in stock for $29.95 - http://www.markertek.com/SearchProduct.asp?item=NA%2DBF&off=72&sort=prodPart #NA-BMX.
Quote from: ebag4 on 12 Nov 2007, 05:24 pmGeorge (Zybar), do you have any initial observations regarding how well the DCX2496 works with the Bolder analog modded Squeezebox with and/or without the Burson Buffer?Thanks,EdNot yet...hang in there.George
This weekend...I promise.Sunshinedawg will be visiting me and make sure that we do lots of different tests while he visits.George
Mike - In reading the Didden kit details it sounds like you have to fabricate the ribbons yourself. Is that correct or did he provide pre-made ones? That looked like a real pain to get right. Tom
Thanks for the link Mike. Mine arrived today already - FAST!
Quote from: TomS on 16 Nov 2007, 08:12 pmThanks for the link Mike. Mine arrived today already - FAST!I just hope it was the right one. When I ordered it was from work and I wasn't 100% sure if a male or female was needed and for some reason I didn't think to pull the manual from Behringer. If it's the wrong one I apologize, if it's right that's great. UPS shows my order coming on Monday so I'll know then. Do you have a DCX on hand to verify it's the correct gender? If not hopefully Markertek has a good return policy. Mike
Quote from: zybar on November 12, 2007, 02:59:07 pmQuote from: ebag4 on November 12, 2007, 01:24:09 pmGeorge (Zybar), do you have any initial observations regarding how well the DCX2496 works with the Bolder analog modded Squeezebox with and/or without the Burson Buffer?Thanks,EdNot yet...hang in there.GeorgeThis weekend...I promise.Sunshinedawg will be visiting me and make sure that we do lots of different tests while he visits.George
