0 Members and 1 Guest are viewing this topic. Read 8047 times.
I am currently running a Bolder analog modded SB3 into a Burson Buffer and then on to my DIY amp4. I am considering going to an active crossover (namely the Behringer DCX2496) using multiple amps. My question is, would there be any reason to keep the Burson Buffer if I am adding a stage between it an the amps? My gut tells me that there would be no reason to since the goal of the buffer is to match the source to the amp but I want to know what you think.Thanks!Ed
George (Zybar), do you have any initial observations regarding how well the DCX2496 works with the Bolder analog modded Squeezebox with and/or without the Burson Buffer?Thanks,Ed
When fed a digital signal, some digital signal processors (DSP's) can alter the digital signal content past 0dbfs (pre-D/A), which of course results in digital clipping and distortion. I don't know if the DCX2496 operates like those other DSP's -- but if it does, then you might want to be careful about this aspect when used this way. [Does the DCX2496 have a clipping indicator?]A little digital attenuation pre-D/A can be a very good thing with these DSP's. Paul's warning about "Keep the levels inside the DCX2496 as high as possible..." is very good advice - just remember that the "as possible" part means not too low, but not too high either!
This all makes perfect sense now that those with some experience have chimed in. Clayton was using a Modwright LS36.5 preamp after the tube DAC, which is both balanced and probably has gobs of output. I never really connected why he did this until you fella's laid it out so nicely. I kinda' like the idea of pumping up the Burson buffer gain or maybe even a balanced (double) buffer version, then attenuating the back side of the DCX (4 or 6 channels depending on how many bass panels/amps). Seems like you'd need the Didden 6-channel output mod to do it all the right way. I'd still prefer to go Squeezebox digital out to DCX digital in somehow, if the interface could be worked out. Let us know how this all works at the Tweek Geek GTG. Tom
I found that it has greater than 15 dB of headroom when coming in with a full bore signal. It will not clip as long as you reduce the output levels accordingly... i.e. the output stage clips at around pro-levels but the internal signal processing has very good headroom above pro levels.-Paul
If the input signal is 0dbFS and the unit is programmed with no filtering or EQ or level adjustments the outputs will not clip. However, once you apply a crossover filter, say a LR24, the waveform crest factor will change and the unit will clip and light the output clipping indicators. Of course, if you program some boost or level increase the unit will also clip. In this type of situation where the input is really "hot" and the volume control is downstream it's best to set the input level controls at about -3db.
I think the only way the DCX2496 should be used is with large input levels that are not volume controlled. (Multi-channel volume control downstream.) The specifications (dynamic range, S/N ratio) say this shouldn't be necessary, but practical experience from a few years now has proven to me otherwise. Smile
Or just buy EXACTLY this:http://www.fullcompass.com/product/264015.html
Makertek has these in stock for $29.95 - http://www.markertek.com/SearchProduct.asp?item=NA%2DBF&off=72&sort=prodPart #NA-BMX.
