FS: Parasound HCA-1500A THX Ultra 2-Channel Amplifier - SOLD
0 Members and 1 Guest are viewing this topic. Read 1508 times.
se-riously
** UPDATE:  SOLD  **
For sale is a Parasound HCA-1500A THX Ultra certified 2-channel amp featuring 205 watts at 8-ohms stereo, 315 watts at 4-ohms stereo, and 630 watts at 8-ohms mono. This amp weighs 40 pounds and is built like a tank. It was purchased in 2003, and has been sitting in my closet for 2 years ever since I bought a Parasound New Classic 5125 for a 5-channel setup. The 5125 serves my needs, so this one is for sale. Absolutely no scatches or marks. I will ship in the 5125's box. I'll post photos tonight.
Price:  $480.  Buyer pays actual shipping via insured FedEx Ground. Add 3% if Paypal is used. Personal checks and money orders are fine too.
Features:
Designed by John Curl
THX certified by Lucasfilm Ltd.
Independent power supplies for each channel
Massive 1 kVA toroid power transformer
60,000 µF computer-grade capacitors in power supply
Multiple polystyrene film bypass capacitors in power supply
DC Trigger Auto On Feature
Cascoded Class A input stages with matched J-FET pairs
Handpicked complementary MOSFET transistors in high voltage driver stage
8 complementary pairs of 15 ampere 50 MHz output transistors
Output transistors direct-coupled to speakers without LRC networks
DC servo direct-coupled audio circuits with 0.8 Hz rolloff
High-bias Class A/AB operation
Gold-plated metal structure RCA input jacks
Gold-plated looping output jacks
Multiple temperature sensors and silver-cadmium relay protection
Glass epoxy circuit boards, double-sided for precision
Custom designed audiophile-grade AC power cord
Multiple Protection Circuits
Specifications:
Continuous Power Output - Stereo:
205 Watts RMS x 2, 20 Hz-20 kHz, 8 Ω, both channels driven
315 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
630 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
60 amperes peak per channel
Slew Rate:
> 130 V/µsecond
Frequency Response:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Impedance:
33 k Ω
Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.2 V for full output
S/N Ratio:
> 110 dB, input shorted, IHF A-weighted
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
w 19" x h 5 1/4" x d 16", h 5 7/8" with feet
Net Weight:
40 lb
« Last Edit: 6 Nov 2007, 07:00 pm by se-riously »
