Pricing for 10 Series DIY kits?
0 Members and 1 Guest are viewing this topic. Read 1489 times.
Theo
« on: 5 Nov 2007, 05:52 pm »
Hi Jim,
Have you come up with the pricing for the 10 Series kits?  I want to start budgeting for a couple of these.
hagtech
    • http://www.hagtech.com
Re: Pricing for 10 Series DIY kits?
« Reply #1 on: 5 Nov 2007, 08:17 pm »
The HA-10 will be offered as a half-kit, aka the CASTANET.  All of the other TEN series are slated as fully assembled machines only.  I expect the CASTANET board to be $99.  Will come with a few pieces of nuts & bolts.  If you want professionally made front and rear panels for the chassis (black anodize with white lettering), you'll be able to order them for $72 direct from the manufacturer.
jh
