The Ripper and Moving-Coil cartridges
0 Members and 1 Guest are viewing this topic. Read 1144 times.
Kyle_C
« on: 2 Nov 2007, 07:56 am »
Hi Jim,
Can the Ripper can be modified to accomodate moving-coil cartridges? Because it's based on the Bugle I'm assuming it could be set for 60dB of gain? The Audio-Technica OC9ML/II has an output of 0.4mV and A-T recommends a load of 20 Ohms. How do you think the Ripper would perform with that cartridge?
hagtech
    • http://www.hagtech.com
Re: The Ripper and Moving-Coil cartridges
« Reply #1 on: 2 Nov 2007, 06:40 pm »
Yes, you can change gain, just like a BUGLE (same phono circuit).  Also can set loading to whatever you want.
jh
