New cartrdrige for MMF-5 or just stylus GLDD012GX ?
0 Members and 1 Guest are viewing this topic. Read 1937 times.
Hoots
« on: 31 Oct 2007, 06:52 pm »
Any recommendations?
My Goldring 101 2GX stylus rides low and has lost it's stiffness.  I feel I need either:
1. a new stylus:   $160-$225 new  GLDD012GX  OR D42 seems like an upgrade and will fit
2. a new cartridge:  the same 101 2GX lists for $300
3. a different new cartridge -- suggestions?
4. a whole new setup -- my perception is that a notable upgrade would be over $1k to something like the SCOUT so I may delay that purchase.
I listen mostly to used rock lps but also new 200g rock and will be buying some 45 rpm BLUE NOTE re-issue jaz lps.
« Last Edit: 31 Oct 2007, 09:03 pm by Hoots »
Wayner
Re: New cartrdrige for MMF-5 or just stylus GLDD012GX ?
« Reply #1 on: 31 Oct 2007, 09:29 pm »
Well, :peek: as the official Audio Technica AT440MLa pimp, I must chime in here  :D!!! That little $89 MM will do wonders, when set up properly. I'm sure the "other pimp" will also chime in with his favorite brand. Both are high on my list.
Wayner  aa
linkweewee
« Reply #2 on: 31 Oct 2007, 10:20 pm »
Listen to the AT pimp.  :thumb:
TheChairGuy
« Reply #3 on: 31 Oct 2007, 11:17 pm »
For an MMF-5, this pimp says go for the At440MLa, too. There's just a lot to that cartridge for $89...remarkable, really, in this day and age.
Now if it was a fluid damped arm I'd have to give the nod to the wonderful Grado (Black thru Gold), however...
:wink: John
twitch54
« Reply #4 on: 1 Nov 2007, 01:52 pm »
I'll chime in and vote for #3......... a Benz Micro 'Ace' in your choice of output, the lower the better IMo, if you have the phono-pre with enough gain.
I used this cartridge for sometime in my previous TT (Music Hall mmf-9) and couldn't have been happier !! I listen to damn near everything; Classical, Jazz, Blues, 60/70's rock, you name it.......... except NO 'Rap Crap' !!
Hoots
« Reply #5 on: 22 Nov 2007, 01:18 am »
I listened to the Audio Technica on a Rega p3 and thought it sounded like the treble was boosted...but it did track well.  The other cart I heard on that same table was a SURE that is popular which sounded more balanced to me.
I purchased the Goldring D42 stylus for my Music Hall MMF-5 which is an upgrade and plugs onto the Goldring cartridge that came stock.  This is supposed to be a top performing MM stylus and it is plug and play in seconds.   So far I love the sound.  I can't really compare it to all the other options but I'm very happy with my turntable and cartridge.
The D42 was a modest premium over the stock stylus, plug & play, I needed a new one, and it got great reviews as a top performing MM cartridge so I gave it a shot.  I'm happy with my turntable and think my next upgrade would be to a $1500+ setup instead of trying options in the sub $1k range.
Wayner
« Reply #6 on: 22 Nov 2007, 10:00 am »
A Rega has no VTA adjustment so any cartridge not fitted properly would probably sound trebly. I have a P3, RB300 combo with an AT440MLa in it and I did shim it up about 1/32".
Good your happy with your set up. I think it takes a while (and money) to find the right table/cartridge combo that will keep the smile going.
Happy turkey day.
Wayner
Hoots
« Reply #7 on: 25 Nov 2007, 04:03 am »
The P3 I heard also had a shim for VTA... any other setup suggestions?  The Michael Fremer setup video was one of the references used when setting up the Rega.
