Ripper - blown LED
0 Members and 1 Guest are viewing this topic. Read 1445 times.
nimrod
Ripper - blown LED
« on: 28 Oct 2007, 09:29 pm »
I built a Ripper a while back and everything was working fine. As I already have a Bugle (power supply, upgraded parts, etc.) I tried the Ripper as a phono stage for the first time today. Worked fine. I disconnected the TT and line out and reinstalled them back to the Bugle. Then I noticed that the power LED on the Ripper was no longer lit. I checked R6/11, and the +/- 10v test points and they're fine, but I'm getting 19.6 volts at the LED. Is this normal, or did I blow Q1 and/or Q2?  I'm pretty sure I didn't power the Ripper down before I disconnected the TT and line out. Jeez, I hate these 'learning opportunites'  :evil:.
hagtech
    • http://www.hagtech.com
Re: Ripper - blown LED
« Reply #1 on: 29 Oct 2007, 02:03 am »
The LED floats between supplies.  It should have about 3V across it (forward voltage on a blue LED).  But if blown or open, then you will get the full 20V of supply (+10V - -10V).  Perhaps it is just a broken solder joint?  Possible the LED went bad.  Although it would be the first one I've seen.
jh
nimrod
« Reply #2 on: 29 Oct 2007, 03:01 am »
Thanks for getting back so soon. :D Well, mark this one down. Busted LED. Do I get a prize for being the first?  :lol: Just my luck (picture black cloud over my head, Murphy dogging my every move).
