Integrating BP-25 into a HT system.
0 Members and 1 Guest are viewing this topic. Read 4237 times.
govcon
« on: 11 Sep 2003, 12:35 am »
I was wondering if Bryston has any modifications in the pipeline for a direct pass through for the BP-25 to better integrate my current 2 channel system with a HT.  If not, what are my options?
Thanks for any advise.
jethro
« Reply #1 on: 28 Oct 2003, 11:21 pm »
I was wondering if you could give a few more details? I'm looking into seeing how I can upgrade my BP-25 with the DA option and use it in my HT as a DAC.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 8 Nov 2003, 12:37 am »
Hi,
The DAC upgrade in the BP25 can not be used as part of the HT system because the 5.1 bitstream has to be decoded first.
We have discussed a pass-through option but have not reached a conclusion on that one yet.
james
John Casler
« Reply #3 on: 8 Nov 2003, 01:21 am »
Hi Govcon,
Why not just set the volume at 12:00 and use one of the aux inputs of the BP25 for the L&R outputs of your receiver?
Run your speaker level set up program in your reciever or pre/pro to set volume levels, and you're good to go.
All you need do then for HT is:
1) turn down the volume
2) select the input on the BP25
3) set BP25 volume to 12:00
4) start your HT as usual
« Reply #4 on: 8 Nov 2003, 01:18 pm »
Hi John,
You could do it the way yousay except a true pass-through wough not have the volume control in the way and would be at unit gain.
james
John Casler
« Reply #5 on: 8 Nov 2003, 02:19 pm »
Quote from: James Tanner
Hi John,
james
Yep,
The only other options then are:
1) wait for "pass-through"
or
2) Get the SP1.7  :mrgreen:
I like option 2 :wink:
jethro
« Reply #6 on: 8 Nov 2003, 05:20 pm »
Hi,
james
I think the following is different from  what the thread originator intended and a bit off topic, but ...
One could connect a cheapish DVD player to a digital input on the  BP-25DAC, take the BP-25 DAC analog tape outputs, connect them to the analog inputs of an SP-1.7, and run in 2-channel bypass mode. This would give the owner the advantage of having the better DACS (from what I have read, no personal experience) in the BP-25DAC when connected to an HT system, and the ability to remove the BP-25DAC/DVD  from that HT system and create a nice compact 2-channel only system by adding an amp and speakers. Sorry about the run-on sentence. This is the advantage I see of upgrading a BP-25 to the DAC version instead of waiting for a separate Bryston DAC box.
govcon
Thanks for the replys
« Reply #7 on: 16 Nov 2003, 02:41 pm »
Looks like I'm stuck with John Casler's suggestion for now...until Bryston decides to add a pass through option to the BP25.
Mr. Tanner, do you know if the chances are good that a pass through option is going to happen?
I would like to keep the BP25 in my system because of the nice sound quality, the balanced in/outs, and the phono pre.
Thanks to all that responded.
« Reply #8 on: 16 Nov 2003, 08:11 pm »
Hi govcon,
I am sorry but there is no pass through option planned for the BP25.
james
