0 Members and 1 Guest are viewing this topic. Read 16953 times.
May not be enough for a SB3. A thread a while back on the Slimdevices website forum indicated that the SB3 is capable of drawing >1A at various points in its operation. Standard engineering practice in a case like this is to derate around 50% beyond what you'd need. A supply capable of providing at least 2A would be a safer bet.
For a SB3, there are a couple options. Use a jung to replace the 3.3 reg, which I am pretty sure it could handle. Or, take some stuff of the 5V input, like the display power, and have a seperate supply for that stuff. Not a simple drop in kind of thing.Randy
Sorry Randy I didn’t mean to take you off topic. There is a lot of interest in power supplies in general. RegardsPaul
Not much has low-Z at tens of MHz. Other than bypass caps.Agreed that impedance that is not flat across the audio band is the best approach. Some will disagree, which is fine.Pat
Hi BradThanks for the info, I did know that Peranders has a jung version too, but I have not tried his. I guess SM would not be a big deal, there aren't that many parts. I wonder how his SM version compares to ALW's through hole Jung?
