RCA versus AES/EBU output on HAG USB?
0 Members and 1 Guest are viewing this topic. Read 1447 times.
rickmcinnis
« on: 22 Oct 2007, 07:51 pm »
Is there any difference other than the connector?
I can use either input.
Can the "RCA" board be used for AES/EBU?
Does the AES/EBU version add electronic compnents to the PCB?
Which one do you use?
THANKS,
Rick McInnis
hagtech
    • http://www.hagtech.com
Re: RCA versus AES/EBU output on HAG USB?
« Reply #1 on: 22 Oct 2007, 10:58 pm »
The difference is the output connector and impedance.  RCA = 75 ohms, XLR = 110 ohms.  The data is identical for each.  I use the RCA version.  IMHO, the XLR has no advantage whatsoever, I only make it for those who have DACs lacking the 75 ohm input.
jh
