0 Members and 1 Guest are viewing this topic. Read 3701 times.
IIRC, the driver cut-outs in the SM6.9 would fit the ScanSpeak 8545 woofer and the 9300/9500/9700 tweeters.So rip out the Vifa drivers and the crossover, install the ScanSpeaks, and biamp.
If I update the current drivers and tear out the xover, I'll need some means to adding the xover function to the connection between pre-amp-out and amp-in, right? If that's the case, any advice on what to use for the xover between the pre-amp and amp, and how best to adjust/calibrate it for the new drivers?
Alternately, I was also thinking of replacing the 6.9 drivers and xovers with the 9.0 drivers and the Dennis Murphy xover design. I thought I read somewhere that the 6.9 cabinet and the 9.0 cabinet had about the same volume, not sure if the driver cutouts are the same.
