CORNET (classic) Available Again as Kit
0 Members and 1 Guest are viewing this topic. Read 1552 times.
hagtech
« on: 18 Oct 2007, 09:32 pm »
For a limited time, I am selling the original CORNET board in a "box/2" format.  That is, it comes with the production chassis (blue) and a separate line voltage select board.  Same circuit as CORNET2, smaller format.  $189.
www.hagtech.com/cornet.html
jh
gab
Re: CORNET (classic) Available Again as Kit
« Reply #1 on: 21 Oct 2007, 03:57 pm »
Jim - does the Piccolo board fit inside the chassis in order to end up with an "MC" version?
hagtech
« Reply #2 on: 21 Oct 2007, 05:41 pm »
Yeah, that's how I built the MC.  It's not easy to do; drilling holes in the main board, 1.5" or so of standoffs (to get the pot shafts sticking through the bottom panel just right), and re-wiring of connectors gets pretty tight.  Anyone truly adventurous can give it a try.  I'm not going to write up any instructions though, as it is too easy to mess up your phonostage by attempting such.  It just plain works better (mechanically) and is less risky to build the machines separately.
jh
