Hi George,
I use these enclosures for my AKSA 55 amps, though I use the 3U size (HB-5130). I have built a couple of other amps in the 2U size (HB-5125) and I'm sure you could squeeze an AKSA into one. The limiting factor is the height of the AKSA PSU with wires protruding at the top.
I like these enclosures because to front, back, top and BOTTOM panels are removable. This allows you to get access to the bottom of the PCB without removing it from the enclosure. During construction, the 2 side panels are held together by a frame of sorts, so the panels don't get scratched or get in the way.
There are quite plain to look at, nothing special, but better than some I have used. The front and back panels are aluminium, so cutting holes is easy. The side panels are steel, so cutting them is more difficult. I imagine a AKSA 100 will have the 2 heatsinks on the sides rather than the back like my AKSA 55.
The enamel coating on the panels is quite thick which causes the panels to be insulated from each other. So a little care is required to ensure all metals parts are connected to the safety earth.
If you can get a Electus Distribution account you can get these enclosures (any Jaycar stuff) at greatly reduced prices, usually 30% to 40% off.
regards
