0 Members and 1 Guest are viewing this topic. Read 2076 times.
Your right, a common problem, and it must be your turn
Differences in chassis potentials are usually caused by "leaky" power transformers. An AC volt meter can help find the problem.
Due to the fact that most audio equipment in your installation is powered by the mains voltage, an unavoidable hum voltage residual is induced on all cabinets and audio grounds. At all audio devices these residual voltages are of different magnitude (or phase) and will balance out by means of ground currents flowing through the shields of your interconnecting cables.Generally, these ground currents are in the same order of magnitude as the audio signal currents being transferred (microAmperes), and thus are likely to interfere, thereby reducing transparency and imaging.With the van den Hul POLARITY CHECKER, you can simply fine-tune your audio system to eliminate, or at least strongly reduce, these residual ground currents and thus improve your system’s performance.
