Position of MPS-2
0 Members and 1 Guest are viewing this topic. Read 2220 times.
ashtarul
Position of MPS-2
« on: 14 Oct 2007, 05:16 pm »
On the on-line version of the BP26 Owner's Manual, there is a little box at the bottom of page 2 that states "...optimum performance will be achieved when the power supply is positioned above the preamplifier."
My question is HOW and WHY?
Thunder
Re: Position of MPS-2
« Reply #1 on: 14 Oct 2007, 11:03 pm »
Best performance is when they are on their own shelves/stands.
Wizard454
« Reply #2 on: 15 Oct 2007, 12:05 am »
I have my BP26 Preamp section stacked on top of the power supply and have not had any issue.
Thunder
« Reply #3 on: 15 Oct 2007, 12:43 am »
Stacking won't cause the units to fail but you will not be maximizing audio performance with this configuration. Proper isolation of any component within a high resolution system will produce an audible improvement, at least to my ears. The best available is SRA IMHO.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 16 Oct 2007, 05:09 pm »
Because the Toroidal power supply transformer is very large in the MPS-2 the magnetic radiation is a factor when placing the BP26 signal preamplifier section.
If you place the MPS-2 directly on top of (as opposed to below) the BP26 it buys you about another 3dB of signal to noise ratio.
If you place the BP26 and the MPS-2 on different selves (about 3 inches apart) it buys you another 2dB of signal to noise advantage over the top position.
james
ashtarul
« Reply #5 on: 16 Oct 2007, 06:22 pm »
Thanks, kind of confirmed my line of thought. These results were actually measured I assume?
« Reply #6 on: 16 Oct 2007, 08:16 pm »
Yes measured.
james
ashtarul
« Reply #7 on: 17 Oct 2007, 05:08 am »
Thunder, excuse my ignorance but what is SRA?
ashtarul
« Reply #8 on: 17 Oct 2007, 08:00 am »
I think I'll answer my own question. SRA - Silent Running Audio
Correct?
Thunder
« Reply #9 on: 18 Oct 2007, 01:32 am »
Correct?
Correct.
