Bugle Kit complete... Rolled off highs...
0 Members and 1 Guest are viewing this topic. Read 2834 times.
8thnerve
« on: 8 Sep 2003, 01:19 pm »
I just completed the bugle kit and the bass is strong, the mids are a little recessed but the highs are rolled off almost completely.  I did not see in the manual what I should be looking for with my multimeter to find the problem.  Where should I start?
hagtech
« Reply #1 on: 9 Sep 2003, 04:30 am »
8thnerve,
Did you add resistive loading on the input?  Check to make sure you have about 50k ohms on the input.  Running this low can kill highs.
Normally, the Bugle is a wideband design with a -3dB point well past 100kHz.  There should be no audible rolloff of treble.
It's possible some of the resistors were put in the wrong place.  Or maybe you used other caps?  Check to make sure they are 0.22uF and 0.01uF.
jh
