All speakers in my home "clicking"! Help!
0 Members and 1 Guest are viewing this topic. Read 1374 times.
yooper
« on: 11 Oct 2007, 10:10 pm »
Recently, I noticed a very, very fast clicking noise emitting from my system's speakers (tweaters) which is loud enough to be heard from the listening seat while a source is not playing.
Today, I decided to try to isolate the issue and unplugged everything but the mono amps (always on) but still hear the noise.  I then heard the same clicking noise from an X10 ir command center and thought I found the culprit...nope, it to is picking up the noise.
I went to a computer in another room, and a slimdevice in the upper bathroom, turned up the volume on both without a source playing, same ticking noise from everything.
I unplugged the fridge, microwave, camper, among other items and it wont go away.
Any ideas?
Mark
IronLion
Re: All speakers in my home "clicking"! Help!
« Reply #1 on: 11 Oct 2007, 10:23 pm »
Do you or anybody in your family use a blackberry or similar device?  They tend to produce very noticeable interference from some sort of burst transmissions as they constantly update emails, etc.
yooper
« Reply #2 on: 11 Oct 2007, 10:30 pm »
Thanks Ironlion,
No, we don't.  I have been trying to remember anything that may have changed, or has been purchased within the last few weeks....other than a couple cell phones, nothing.
I even manually disconnected my cable and broadband connection, thinking and hoping I might isolate the problem.  No luck.
IronLion
« Reply #3 on: 11 Oct 2007, 10:36 pm »
Its probably not the cell phones, but have you tried turning them all off?  Might be worth a shot.
yooper
« Reply #4 on: 11 Oct 2007, 10:50 pm »
I did.  I should also try to give a better description of the sound.  It resembles the noise of a noisy power line transformer.
Mark
Wayner
« Reply #5 on: 11 Oct 2007, 10:53 pm »
Does the clicking have a time interval, and if so is it like every second, or what?
W
yooper
« Reply #6 on: 11 Oct 2007, 10:59 pm »
The clicks are to fast to count.  My best guess is about 15 per second and is constant, no variation.
Mark
Wayner
« Reply #7 on: 12 Oct 2007, 02:09 am »
I would try the circuit breaker box for starters. I would find which breaker has your system on it and leave that one on. Then I would shut off all of the other breakers to see if the clicking has stopped. A systematic turn-on and check may at least produce a breaker that shuts off the offending noise, making it easier to narrow down the culprit. It could be as stupid as a TV, garage door opener or a phone. That brings up the other question. Is it coming thru the AC wiring, or are you picking up a "broadcast" type of noise?
W
yooper
« Reply #8 on: 12 Oct 2007, 08:40 pm »
Thanks Wayner,
If time permits, I'll give your suggestion a try tonight or tomorrow.
Regarding AC or "broadcast" type noise, it is AC noise.
Thanks again,
Mark
