Univeral Harmony remote with B100DA?
0 Members and 1 Guest are viewing this topic. Read 1193 times.
gregeas
« on: 11 Oct 2007, 03:15 pm »
I just bought the B100DA without the remote option and I'm wondering if I can use a Harmony remote to control it.
In other words, does the B100DA have an integrated IR receiver, or is this only included if you purchase the optional remote?
Looking forward to playing with my new toy tonight.
Kris44
Re: Univeral Harmony remote with B100DA?
« Reply #1 on: 14 Oct 2007, 05:13 am »
Hi Gregeas,
Yes, I am using a Harmony 520 to control my BP 16 DA preamp with no problems except I don't have the ability to control balance. All other controls work fine though.
Kris
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 15 Oct 2007, 12:53 pm »
Hi,
All B100's have the IR receiver.
james
